02-10-2006, 07:33 AM | #1 |
Member#: 29400
South East
'01 RS - Car stutters after filling up
Not sure what's causing it ... every time I get gas, the car stutters for ~ the first 5 miles ... new fuel filter ... running 89 octane gas ... any thoughts?
Car has 111,000 miles on it ...
02-10-2006, 09:21 AM | #2 |
Member#: 3148
TXIC
Vehicle:12 Ford F150 EB 00 BRP 2.5RS (again) |
If you did a search under my name, you would find a very similar thread...
Stop topping the tank off! When the Impreza is topped off, it floods the charcoal canister inlets and cause the car to stumble for a bit until the lines clear out. |
02-10-2006, 09:26 AM | #3 |
Member#: 11808
Over filling too much will get gas into the charcole canister and it takes some time to convert to fumes so the engine can suck it out. Shut of gas at the first or second nozzle click.
02-10-2006, 11:18 AM | #4 |
Member#: 29400
South East
I do shut off the gas at the first nozzle click ...
02-10-2006, 11:31 AM | #5 |
Member#: 73398
South East
Vehicle:04 11 VW GTI APR Stage 1 (300ft/lbs) |
You may have to listen for the "cup filling up" sound and stop before the auto-click-off. I've noticed a lot of gas nozzles won't click until it's filled enough that there's a pool of gas outside the flap, sometimes enough to run down the side of my Forester.
Fun, fun. Smoke anyone? |
02-10-2006, 12:30 PM | #6 | |
Member#: 80670
02-10-2006, 02:40 PM | #7 | |
Member#: 51642
TXIC
Vehicle:2008 WRX WRB |
When I read Tex's thread and followed the recommendation, it has done it less and less. The problem has not been eliminate, but is managable. BTW the car did the exact same thing after changing fuel filter, plugs and wires. It has got to do with the charcoal canister. |
02-10-2006, 02:52 PM | #8 |
Member#: 29400
South East
okie dokie ... I'll just have to pay attention and try it a few times ...
thx for the input guys |
02-11-2006, 10:01 AM | #9 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
BTW, now that these cars are getting older, the charcoal canister has a finite life.
It may be telling you it is time to replace it. |
03-11-2006, 01:39 PM | #10 |
Member#: 51642
TXIC
Bumps.....
Yesterday my car began doing this again, but I have half a tank of gas. If I am cruising I can feel the car lose power for split seconds at a time. Less noticable the higher the gear. Major bucking in 1st gear. Could this be caused be a failing canister? Bad spark plug? Check my codes at autozone and there was nothing other than the P0420 I get all the time. Any thoughts? |
03-11-2006, 05:46 PM | #11 |
Member#: 3148
TXIC
The fill up problem is more noticable in higher gears (low engine load)... I would be looking to change out the plugs and maybe wires in your car... how long have you been on those wires? plugs?
03-17-2006, 10:13 AM | #12 | |
Member#: 51642
TXIC
Really just changed the plugs about 2 months ago (NGK6E-11) and the wires were changed out toward the end of last year (OEM). Car seems to running fine, but yesterday I did notice the symptomes again. I haven't taken a trip more than 5 miles yet. Do you think it could be a dirty injector(s)? |
03-17-2006, 12:15 PM | #13 |
Member#: 109954
Vehicle:1995 Impreza L Red |
Similar Problem
Hey, I'm facing a similar problem and I don't want to lose the attention of you all who seem to be familiar with it by starting another thread. I'm wondering if the problems with the full tank might be found on a 1995 Impreza also. When the tank is full, and idling, the tach often drops down close to zero (but hasn't ever cut off). That makes starting a bit rougher than desired. I just bought this car and it was full but hasn't been doing this for a few days, now that there's less gas. Coincidence? I hope not.
Start up trouble after fill up. | mmor101 | Normally Aspirated Powertrain | 0 | 10-24-2005 01:27 AM |
Car jerks/studders after fill-up | DreddRS25 | Service & Maintenance | 7 | 03-09-2005 06:24 PM |
Engine stutters after filling-up? | DreddRS25 | Normally Aspirated Powertrain | 9 | 05-01-2004 10:10 AM |
Dripping fuel after filling up | Senger | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 11-15-2002 02:46 PM |
Why does my car have a strong gas odor after filling up? | Eric SS | Normally Aspirated Powertrain | 2 | 09-08-2002 01:40 AM |
