Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 02-12-2006, 01:03 PM   #1
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
Default 2000 outback bucking and CEL cl #2 missfire
So heres the story, My parents 2000 outback EJ25 SOHC at 100,000 mi started bucking and running on 3 cyls and showed corrosion on the #1 (which the spark was arcing off and grounding to a bolt on the coil pack) the coil and wire so we changed the coil, changed wires, and changed plugs to bosch plugs. Now the CEL says its the #2 cyl.
It is still currently bucking just the same as before and I'm out of ideas so any help is appreciated.
Thanks in advance,
Justin
Kawikid20o2 is offline   Reply With Quote
cel help needed, missfires on all cylinders csimp3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 12-02-2008 08:11 PM
car bucking and surging, o2 sensor? cel = p1137 imprzya Normally Aspirated Powertrain 5 06-29-2005 04:07 PM
Need paint name and code for 2000 Outback MDRex Outback Forum 4 05-16-2005 07:31 AM
Struts and Springs for 2000 Outback wagon G.Subramaniam Outback Forum 1 02-20-2005 06:40 AM
2000 legacy wheel and foglight ? (xpost from outback forum) aerosaaber Legacy Forum 1 12-18-2004 07:03 PM
