02-13-2006, 10:52 AM | #1 |
Member#: 74827
Vehicle:1999 impreza rs rbp |
need help
Alright I am replacing my headgaskets on my99 rs. While I was attempting to loosen the drivers side cam pulley bolt, one of the idler pulleys, which i had loosened. came off, and my timing belt slipped and that cam pulley also moved. So basically I have an engine with none of the timing marks marked on the belt or the pulleys. THe heads are off now, and the crank is at TDC, what can i do to rotate the cam pulleys to where they need to be when the 1st cylinder is at TDC? thanks
Brent
02-13-2006, 01:46 PM | #2 |
Member#: 74827
ok i think i figured out how to get the drivers cam pulley aligned, but now my question is about aligning the passenger side pulley as well. i know i can put the arrows on the crank and drivers side cam pulley at 12 o'clock, but what can i do for the other one
02-13-2006, 02:09 PM | #3 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
Not sure if this'll help, but this is for the 2.2L SOHC which should be close enough to help you get the timing right.
http://www.ravensblade.com/car/techd...timingbelt.pdf |
02-13-2006, 04:07 PM | #4 |
Member#: 74827
i have the FSM, but what I am unsure about is which aligment marks to line up. TDC is different then having all the marks on the crank sprocket and cam pulleys at 12 o'clock.
Hard Drive Recover Help much needed... ATA RAID 0 knowledge needed HELP PLEASE!!! | 2k2 | Off-Topic | 71 | 07-13-2023 08:42 PM |
NEED help! 2.5RS in Central Jersey | pMak26 | Tri-State Area Forum | 9 | 06-04-2010 08:50 PM |
Anyone need help with an install? | RubbleDTD | Mid Atlantic Impreza Club -- MAIC | 0 | 06-03-2010 05:23 AM |
Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line | STR8OUT | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 04-18-2003 12:11 PM |
Need help!Need flywheel bulletin from SOA.Please help. | RallyeX | General Forum Archive | 3 | 06-01-2000 07:57 AM |
