#1 |
Member#: 518
NESIC
Vehicle:762 PGT Impreza L, Silverado EXT, Yaris |
![]() Cliff's Notes:
North Ursalia and I just spent the evening trying to diagnose a pissed off knock sensor on the Trunkmonkey Pink Impreza (PGT-prepared 1996 Impreza 2.2 L) to no avail. We're still getting a P0325 Knock Sensor 1 Circuit Malfunction (Bank I or Single Sensor) even after replacing the knock sensor. The weird thing is that it doesn't always come on immediately; you have to put 5 to 20 miles on the car before it comes on. First, what does P0325 actually mean? Continuity between the knock sensor piezo and the block? ECU malfunction? Bad data from the knock sensor (I thought it was either on or off; no data stream). Bad ground? Now, here's the history for those of you with an attention span: ![]() Tossed a P0136 O2 Sensor Circuit Malfunction (Bank I Sensor 2) shortly before Maine Forest Rally, ignored it after talking it over with the service crew, and ran the event. With the exception of a few Rallycrosses and Ice Races the car sat in the garage until I had both the front and rear O2 sensors replaced by SubaruProParts.com last Saturday. Tossed a P0325 (which I'd never seen before) 8 miles from SubaruProParts.com on the way home from having the O2 sensors replaced. Got home, pulled harnesses, checked for corrosion, plugged everything back in, cleared the code, went for a drive, and it didn't toss the code until 8 miles into the drive. Clear the code, 10 miles later it comes on. Clear the code, 15 miles later it comes on. Ran a Rallycross on Sunday. The car showed no signs of hesitation or retarding timing before the Rallycross. The car was constantly retarding timing and hesitating on the drive home. The CE light also occasionally flickered; it kept going out for a split second and then coming back on. This evening North and I pulled the knock sensor which was filthy and corroded, scrubbed the corrosion off the block, and replaced it with a brand-new knock sensor. Went for a drive, I was up on power, and the car was the best it felt since before Maine Forest. 18 miles in I tossed the P0325 again. No hesitation, no retarding timing, just a P0325. So what gives? Any ideas? It's not every day that North Ursalia is scratching his head about an Impreza problem. ![]() ![]()
#2 |
Member#: 43602
NESIC
Vehicle:2005 Outback Sport |
![]() You could try resetting the ECU one more time just to make sure. No problems with the spark plugs, wires, or coil pack that could be causing problems? Something to do with the oil (low or oil filter)? Just throwing out ideas.
#3 |
Member#: 51940
NESIC
Vehicle:2001 White |
![]() batch of bad gas? try seafoaming the engine, or putting some gas treatment in.
(also stupid question) oil change time? |
#4 |
Member#: 518
NESIC
![]() One interesting thing to note:
I just cold reset the ECU using the battery cutoff switch and removed and re-torqued the knock sensor to 17.4 per a few posts in the CEL thread and ScoobyMods.com. After doing that and going out for a drive it only took a mile for the CEL to come on. Then clearing the code would cause the CEL to flicker off, immediately throw a code, and come back on. Interestingly, the motor now idles at 2000 RPM. ![]() Plugs and wires were done about a year (7,500ish miles) ago. Oil and oil filter was just changed on Saturday with the O2 sensors. The ECU has been cold reset multiple times using the battery cutoff switch. And gas shouldn't be an issue; I filled up at the same place I always do. Throw me a frickin' bone here, Mr. Bigglesworth! ![]() ![]() |
#5 |
Member#: 51940
NESIC
![]() odd about the idle....the IAC is woring properly, yes?...
the connection to and from the knock sensor are good, right? no loose ends? |
#6 | |
Member#: 518
NESIC
![]() Quote:
#7 |
Member#: 51940
NESIC
![]() stupid stupid suggestion...but try loosening it. just for fun.
#8 | |
Member#: 518
NESIC
![]() Quote:
#9 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
![]() I'll throw in my guess. Check in resistance across the sensor (I have no idea), then check it from the pins at the ECU harness. See if it changes, bump the car around a bit.
If not that, trace the wires all the way back, see if the wires rubbed through anywhere. My guess is you have intermittent grounding out of the sensor that you can't see. |
#10 |
Member#: 6486
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
![]() So the motor is making no odd noises? Have you checked the timing belt alignment?
Put a stethascope on the block while it's idling and see what you hear. interresting. |
#11 |
Member#: 518
NESIC
![]() Master and Tim, thanks for more things to add to the list. Not enough time to poke at the car this evening but I'll be diving back under the hood again tomorrow night.
![]() Edit: Tim, correct, no odd humanly-audible noises at all. A stethoscope check may reveal something more... ![]() |
#12 |
Member#: 17479
Vehicle:1999 Impreza WRX Silverthorn Metallic |
![]() Try switching gas grades. Maybe your car needs more octane…
#13 |
Member#: 518
NESIC
![]() It may be solved! Tonight I installed yet another knock sensor (thanks North Ursalia!), replaced the PCV, and filled up with 93 even though the car's been happy on 87 for the past 3 years. Cleared the code and put 35 miles on the rally car. No check engine light so far! I'll put another 70 miles on tomorrow driving to and from work (rally car in Boston commuter traffic w00t) and see if the ECU stays happy!
#14 |
Member#: 246132
Vehicle:2000 Impreza 2.2 Green |
![]() Sean, I know this thread is really old, but I just came across it. My 2000 Impreza is having the same symptoms as your car was. Did the new knock sensor, PCV valve, and 93 octane solve the problems for you?
#15 |
Member#: 518
NESIC
![]() Yeah, I never updated this thread, did I? Ha. The new PCV valve solved the issue but, if you haven't replaced your knock sensor yet, I'd replace both at the same time. The car has been run on normal low-octane fuel since then with no issues.
#16 |
Member#: 280082
![]() I know this is an old post, but would anyone mind explaining how a bad pcv causes pre-igniton, knock?
#17 |
Member#: 250463
Vehicle:2010 Impreza 2.5i Silver |
![]() A bad PCV can cause excessive oil consumption and oil has an octane rating of negative 80 bajillion, causing more knock.
Or so I've been told (about the octane, I know a bad PCV will cause excessive consumption). |
#18 |
Member#: 165749
![]() A faulty pcv may allow excessive amounts of oil vapor to enter the intake manifold.
#19 |
Member#: 280082
![]() Thank you, you guys- appreciate the info.
#20 |
Member#: 289098
NWIC
Vehicle:2002 bugeye wagon Radio Flyer |
![]() I know, this is an old thread but i have a question. Is the orientation of the knock sensor super important? I know it's supposed to be 60 degrees relative to the back of the motor, what i'm asking is, if its not exactly 60 degrees will it make a big difference? Say 58 or abouts?
#21 |
Member#: 300551
SCIC
Vehicle:2002 FOZ STI 2.34 Fullers Garage |
![]() I have read those threads too but after putting in maybe 50 i have never had a problem so i would say close is good enough. I also had a 98 legacy that would throw a code if I feed it reg it only liked the good stuff.
#22 |
Member#: 243590
Vehicle:07 forester Silver |
Help: Flashing CEL after replacing O2 sensor | Idratherbsidewayz | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 09-02-2009 08:30 PM |
1997 2.5 NA SLIGHT Hesitation AFTER new KNOCK Sensor | STL97outback | Normally Aspirated Powertrain | 8 | 02-27-2009 12:25 PM |
Replacing knock sensor (1999 Legacy 2.2L) | modenaf1 | Service & Maintenance | 5 | 06-01-2006 12:21 AM |
HELP replacing knock sensor | timmui | Normally Aspirated Powertrain | 3 | 12-17-2004 03:07 AM |
replacing knock sensor | gsgleason | Normally Aspirated Powertrain | 7 | 07-27-2004 05:20 PM |
