Welcome to the North American Subaru Impreza Owners Club Thursday July 9, 2020
Old 04-12-2006, 01:09 AM   #1
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Question 595whp with the GT37 eh - Access ECU/custom blow through MAF
At our little open house this weekend we decided to throw Timís STI with the GT37 on the dyno to see what it would do. As some of you might remember, I ran a GT37/GT40 hybrid last year, which used a GPMoto built header/uppipe, downpipe, and Ti Exhaust. Since I am going to use the full GT40 on the H6, I split apart the 3740, and mated the parts back together with the 4037 to get back the original GT37 and GT40 turbo. Since Iím not going to use the GT37, we put it along with the header/uppipe/downpipe into Tim's STI to see what it would do.
Tim had a COBB protuner pump gas map, so we took the fuel map and leaned it out real quick, and added a bit of timing, threw in some C16 and turned up the boost. Both the pump fuel tune and the C-16 tune were done with Access ECU protuner software. The tune is not optimized due to lack ot time but C16 is very forgiving anyways. I was not really sure what to expect. This has a 1.12 AR hot side and is twin scroll. It is not a ball bearing turbo, and as such is pretty inexpensive. You can rebuild each piece individually, and swap in different wheels and housings.
Tim hasnít gotten around to getting his DTEC installed, so he threw a manual boost controller on it, which worked. The only downside of the manual is that it doesnít provide positive pressure to the second port on the external, and it really doesnít hold the boost flat all the way to redline. No matter what level (18psi-32psi), the boost always peaks a bit more, then rolls a bit to redline. Certainly we will get the DTEC on there and see what we can do.
At about 32-33psi, falling to 29psi at redline, it peaked a bit shy of 580whp uncorrected, 596whp corrected. Take a look at the plots:
The purple is the GT37, and the yellow is the FP Red Tim had on before, also on C16.
Non corrected graphs: (meaningful)
SAE corrected graphs: (meaningless)
That is 564 lb-ft ( 578 lb-ft corr ) of Torque. Thatís pretty snappy. The twin scroll helps the spool a bit, but it is still laggy as hell. Once the boost rolls in, it feels pretty scary fast, especially on street tires. Right at the torque peak the tires just rip loose in 4th gear. Iím sure it will be fun to drag race, and Tim is looking forward to the rain going away.
A couple of other observations:
The car still has the single plate Exede Hypersingle clutch, which is at a state of complete failure. On the dyno, every other pull it would break completely free, and if I ran right away again, while the clutch was still hot, it would hold for a pull. On the street, 4th held every other pull,and 5th breaks free right away. Tim has a Twin plate sitting on the shelf, but we just have not had time to get it in there.
This was using a new prototype blow-thru maf we made, 3.25" ID (corrected 4-21-06) diameter with some custom placement and design, and it didnít hit 5.0Vs (~4.7 volts at 580 whp). Very happy about that! This was using the Access Port with the ProTune, MAF all the way.
The mods are the usual: Perrin FMIC and Perrin Injectors, the turbokit, the block has CP pistons that we slapped in, plus we balanced the motor before reassembly. Stock heads and cams of course. No WI running right now.
These CPs are VERY loose, perhaps on the 4 thou side. As a result, when the car is cold, it smokes quite a bit, and if you jump on it much at all while cold, it burns oil. Once the pistons get hot, very hot, the motor runs perfectly. We did perhaps 10 pulls at 580whp, all in a row, no real delay, and the motor purrs like a kitten. Like the CP guys say, they are race pistons.
When driving, the most noticeable thing other then the peak torque is the feeling that the HP stays pretty flat once on. The larger turbine side shows no signs of letting up. Since this is the stock valvetrain, we didnít really push it above 7k, but from what I can tell, it looks like the HP will keep flat for a while longer.
Since upgrade parts are so cheap, we are going to throw on the GT4088 compressor wheel and compressor housing and run it, just to see how the GT4088 compressor compares.
I posted a while back a few compressor maps, so you can see how the GT37 compares to the GT35R. Have a look.
Take a look at these graphs I put together. These graphs show airflow on the 2.5L (BLUE), and 3.0L (RED), for 4000,5000,6000,7000 RPM at 16,20,24,and 28 PSI.
GT3582R
To read the map, the four lines of dots (going up) are the four boost levels. The for dots on each line (going right) represent 4000,5000,6000 and 7000 RPM. As you can see, the 35R is a pretty good fit. However, notice that at 28psi at 7000 RPM, the H6 is off the right edge, while the 2.5L is in the middle. On the converse, at 6000 RPM the H6 is right in the middle, while the H4 is almost off the edge.
GT37
The 37 is a good match for the 2.5L, but would be a little smaller for the higher RPM on the H6. Due to the slightly better surge side, it should work well.
GT4088
This looks pretty ideal for the 3.0L. The GT40 has a very wide compressor map, and has good efficiency even for the high rpm 28 psi load.
GT3076
You can see that the GT3076 is a perfect match for the 2.5L. On the 3.0L, it would work well at medium boost levels, and probably make great pump gas power.
Anyways, an interesting experiment chaps.
Cheers,
Jeff Sponaugle
PDXTuning.com
PDXTuning is offline   Reply With Quote
Old 04-12-2006, 01:20 AM   #2
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Holy cow! Those are some impressive numbers!
WRXRallyBlue is offline   Reply With Quote
Old 04-12-2006, 01:26 AM   #3
slvr02scooby
Member#: 86628
2002 WRX EJ257
COBB Tuning Surgeline
Great work guys! It was awesome to see this beast on the dyno even with the slipping clutch I look forward to the compressor wheel switch to see what it will do.
And personal thank you to Tim Bailey for taking me out in this car, what a trip!! My car has yet been able to get me aroused since then
slvr02scooby is offline   Reply With Quote
Old 04-12-2006, 02:22 AM   #4
ka mano
Member#: 78022
PdxT built 2.5L 6sp
30R.82, 274/276, H2O+meth
Exciting news and, as always, a great run-down, Jeff. Thanks for the data.
Wanted to clarify: is the header stock or off the GPMoto setup?
kamano
This is for Tim:
ka mano is offline   Reply With Quote
Old 04-12-2006, 02:31 AM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Pretty cool no WI was going on with those HP levels
I need to get my **** running !
Old 04-12-2006, 02:31 AM   #6
my_sti_1
Member#: 86713
04 STi SUPER99 C16
Java Black Pearl
how much whp does a gt35r give?
maxed out of course.
my_sti_1 is offline   Reply With Quote
Old 04-12-2006, 04:05 AM   #7
mrubino83
Member#: 22987
2010 PB EVO X GSR...
.. It's All Stock Officer
Max whp from a 35r is going to depend maily on hot side (0.82 or 1.06), and valvetrain upgrades. and of course, fuel, tune, and dyno...
Stock block/heads/0.82....(this is just an approximation) 420pump/530c16
Stock block/heads/1.06....(again, just an estimate) 440pump/550c16
The EJ257 responds well to a larger hotside, hence the reason for increased power with the 1.06....you can expect slower spool (obviously) and it will really shine up top with some cams/head porting.
The larger hotside is also the reason that the GT37 (1.12 a/r) makes more power than the 35r(which actually has a larger compressor)
Hope this answered your question
And sorry Im Im getting off topic.
Those anre some impressive numbers! Great work guys! any plans to throw that twin disk in any time soon?
mrubino83 is offline   Reply With Quote
Old 04-12-2006, 09:58 AM   #8
c'dalerider
Member#: 92388
04 WRX, 06 STI
wrb x 2,900awhp combo
Kudos!
H6? didnt say in the post.
I think im going to stick with the gt35R for now and see waht type of numbers we can get out of it with my setup. Im looking for 1/4 mile numbers, not necc dyno numbers. Im hoping the 35R can get us into the mid 10's.
c'dalerider is offline   Reply With Quote
Old 04-12-2006, 10:21 AM   #9
my_sti_1
Member#: 86713
04 STi SUPER99 C16
Java Black Pearl
me too but with high 10's.
thanks for posting your results with the gt37 BTW.
Old 04-12-2006, 11:23 AM   #10
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Wanted to clarify: is the header stock or off the GPMoto setup?[indent]
Fixed that above. The header is a GPMoto header, as it is a twin scroll setup and each scroll comes from a R+L bank.
We have not ran a GT35R on this dyno yet, but certainly will soon. I'll post all of the data I get.
That was the real question I was looking at getting some data on. Spool on this setup seems to be on par with the 1.06 hotside, but with less back pressure.
While the GT35R has a great 'peak' value for the compressor, that doesn't really make it 'bigger' in EJ257 speak. If you look at the compressor map, 6000 rpm at 28psi both the 35R and the 37 are in the 76ish % efficeincy (although it looks like the 35R is actually a bit more), however neither are close to the 65 lb/min peak. Also, the 37 compressor map is taller (reaches 3.5 PR with more air flow), which is much more suited for a small motor at high boost.
Kudos!
EJ257 with CP Pistons.
The 35R has been proven by many, and I certainly still like it. However with the right setup, the 37 offers some very good options. The large hotside may allow a more consistant power band to higher rpm, especially with the addition of NOS. The clutch will go in right away, as the car really isn't drivable with the current clutch.
Cheers,
Jeff
Old 04-12-2006, 11:47 AM   #11
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
The best thing about this setup was riding in it. I had to buy new shorts for the ride back to Seattle, after riding in this thing. This post and many others really showcase the real in-depth knowledge of the guys at PDXTuning. I feel bad for people in other parts of the country that can not take full advantage of what these guys have to offer. They need to chance there slogan, to Knowledge is a lot of power.
Token-Negro is offline   Reply With Quote
Old 04-12-2006, 11:52 AM   #12
InfamousDX
Member#: 25413
i feel bad for us east coasters that don't have people like pdx...
sick numbers guys. congras
Old 04-12-2006, 12:12 PM   #13
ShaggyGT
Member#: 19221
2005 Legacy GT (STi)
UR35R/Rotated Intake Mani
Very very impressive. Great job PDX!!!
-Matt
ShaggyGT is offline   Reply With Quote
Old 04-12-2006, 12:22 PM   #14
sb427f-car
Member#: 93766
2005 Busted WRX
Thanks to being rearended
Impressive! Has anyone tinkered with the GT37 with a VNT exhaust housing yet?
sb427f-car is offline   Reply With Quote
Old 04-12-2006, 12:37 PM   #15
23b_Rex
Member#: 79394
02 gda
wrb
omfg.... 4k - 5.5k... what a ride
23b_Rex is offline   Reply With Quote
Old 04-12-2006, 12:45 PM   #16
Zrex11
Member#: 94881
1989 Hoopty Stylez
Road Slipper
True story ^ im only in arizona and i have to say PDX is the shiznit if i was closer they would be the shop for me.
Thanks again for the info guys!!!
Zrex11 is offline   Reply With Quote
Old 04-12-2006, 01:00 PM   #17
fmowry
Member#: 54604
2004 FXT
Cayenne Red (sold)
There's too much useful information in your post. Could you run it through the Ispeed/Crawford converter to confuse us please?
Thanks,
Frank
fmowry is offline   Reply With Quote
Old 04-12-2006, 01:37 PM   #18
ka mano
Member#: 78022
PdxT built 2.5L 6sp
...rrrrOUWW!
ka mano
Old 04-12-2006, 03:01 PM   #19
pio!pio!
Member#: 4190
2008 Impreza WRX STi
anyone @ pdx: what is your opinion on the gpmoto twin scroll header? They are the only ones that make a twin scroll header for Garrett turbos correct? Has there ever been thought to using a JDM twin scroll header but with a custom twin scroll uppipe? Or are the aftermarket twin scroll headers are of sufficient quality
pio!pio! is offline   Reply With Quote
Old 04-12-2006, 03:06 PM   #20
dream
Member#: 37003
2015 WRX
Holy nice numbers!!! When is this Perrin Blow thru going to be available?
Engine bay pics?
dream is offline   Reply With Quote
Old 04-12-2006, 03:25 PM   #21
Caplin 2.5
Member#: 71203
2005 2.5rs
Crystal Gray Metallic
that is one powerful motor, can i have it?
Caplin 2.5 is offline   Reply With Quote
Old 04-12-2006, 04:14 PM   #22
homer227
Member#: 92883
2005 WRB WRX
Now w/ 100% More Hella :)
Nice Work!
homer227 is offline   Reply With Quote
Old 04-12-2006, 07:13 PM   #23
mrubino83
Member#: 22987
Any plans to take this to the wrx vs evo shoot out?
Old 04-12-2006, 07:16 PM   #24
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Talking
Originally Posted by B
...can i have it?
A: You asking for a dyno plot or a time slip?
B: I'm asking for The Car.
A: You want The Car?
B: I think I'm entitled to It.
A: You can't handle The Car.
Old 04-12-2006, 08:21 PM   #25
Division By Zero
Member#: 7555
Sweet, Jeff! Unbelievable.
Division By Zero is offline   Reply With Quote
Out with the RS. In with with the Legacy LTD jdOgg3355 North West Impreza Club Forum -- NWIC 38 05-15-2009 05:48 PM
O Hi, Jose Alvarez - So You Used to Play for the Braves, Eh? OriginalSin Off-Topic 3 01-28-2008 10:37 AM
I got a question for the Canucks, eh. Asinine Off-Topic 10 11-01-2007 10:14 AM
Video - quite the scoop, eh? mhaythor General Community 13 06-23-2005 04:59 PM
So you need help with an install, eh? chrislehr New England Impreza Club Forum -- NESIC 20 10-20-2003 11:55 PM
